MilehighLR3
- Joined
- Sep 23, 2010
- Posts
- 154
- Reaction score
- 0
First, no where did I say any loss was permanent. However there is a degree of sulfation on the plate surface (which is by definition a discharged battery) unless the battery has been allowed to rest in that state for an extended period of time is reversible with the proper charging technology.
Second the smoking gun you're referring to was stated within your own comments . . ..while the Optima will do what you say, provided the charging source has the ability to provide higher current (which an alternator does not unless the RPM's are higher on the engine, voltage is limited by the regulator). While it's doing this "transfer" voltage it is discharging, lowering it's own state of charge, thereby reducing it's capacity.
Unless you've performed a discharge test, to verify the capacity, you only have anecdotal opinion (no offense intended). There is absolutely no possible way a lead acid battery, regardless of construction, will retain 100% of it's capacity below it's 100% state of charge.
That being said, the higher power technology will provide higher capacity(relative to other lead acid tech) at lower states of charge, the higher the discharge rate the better, but not what it would do if it was at 100%, which has been my statement from the beginning of this debate.
Still doubt my statements? Measure the key off open circuit voltage of an Optima Yellow Top, if it is not 13.1, it is not at 100% state of charge.
