Wiper fluid
MIKWIL
I got a 97RR my wiper fluid won't come out, i thought the holes might need to be clean out so i stick a straight pen down them but nothing. I disconnected the hose and nothing came out. What else can I look at? it sounds like it works the wipers move when i push the buttons and the back one works fine
Help pls,
Thank you in advance
Slam
You can try getting someone with pressurized air to blow out and junk... I did something similar once to clean out some a/c lines.
Have someone turn on the washers and listen to see if the pump is even running... could be a bad fuse or bad ground.
