Front Diff(s)
EIGHTLUG
Interesting write up. I contacted the local dealer's service department about purchasing the "factory" fluid through them and they specified 3 Qts total. This is where the can of worms opens. Do those fluid amounts stated in the write up look even remotely close to accurate? The rear diff fluid amount I can work with, still seems low. The reason I say that is, that to me, sounds like the main reason these diffs are failing. Just think about this for a moment....Those instructions are telling you, the entire front diff is being lubricated by a pint of gear oil??!! Can you imagine how much of that pint of fluid is being slung around by the ring gear @ 75 MPH. That leads to a dry pinion bearing and dry output shaft bearings.
That sheds a lot of light on the situation people are experiencing with whining diffs @ 20K miles. That being said, I'll stick to my rule of thumb of filling a diff to 1/3'rd up the pinion bearing. ;) If the pinion seal does fail from being "overfilled" It'd be a lot cheaper and easier for me to replace the pinion seal than it would to eventually replace a ring/pinion assy from lack of lubrication.
tlt
If you are considering going as far as to repair seals, you might also consider bearings, and potentially ring & pinion. The bearings and Ring & Pinion are not available from LR. You can check out my generic post after finally finding a company who could supply the parts. I figure this may be a good reference for other folks beside me with Diff issues.
The best place (only place) I know of that can answer your questions is an outfit I found in S.A. I have been in touch with them, and have a stock ratio rebuilt kit enroute. I understand :: Luck8llc :: is going to be selling them in the US.
There are several gear ratios for the DIII/LR3 model, based upon engine type. You can e-mail Deon there, and he will take care of you. Tell him Todd sent you. You can get his e-mail on the web site, and see their other products. Below is an e-mail I got from them.
NEW LR3 DIFFERENTIAL PARTS AVAILABLE
We are a drive train remanufacturing company based in South Africa specializing in Land Rover drive train products.
:: CENTURION GEARBOX & DIFF CENTRE ::
We have done excessive developed on replacement parts for LR 3 differentials.
1. Crown wheel & Pinion TDV6 & V8 rear differential.
2. Complete bearings & seal kits front & rear differentials.
3. Complete rebuilding kits rear differential.
We have spent enormous time and intensive development and research on developing this product in order to supply a high quality replacement part to the existing LR3 market.
This product have been through stringent testing to ensure manufacturing quality Please contact us in order to obtain distributing rights in your area.
Centurion Gearbox & Diff Centre
Differential Parts South Africa - Opening Soon in South Africa!!
tlt
Here is potentially some helpful information here. I had problems with my Diffs and found that LR does not supply bearings or ring & pinion, only reman units, etc. Although my dealer claimed to give me a repair quote, the fact was they were quoting my a replacement unit, exchange. Anyway after a ton of research I found a company who actually supplies a total kit, at least for the rear.
tlt
tlt
I got my rear locker diff rebuild kit today. I think i'm going to consider the royal purple as well when complete.
In any event, re-engineered to prevent the "whine" people complain about, and should be better than factory new when complete. I am very excited.
EIGHTLUG
Keep us updated on how the install goes. Could you also link the store you purchased your ring & pinion kit from?
