- Joined
- Feb 8, 2011
- Posts
- 3,401
- Reaction score
- 93
Hey Axel... I have the same question, I run slightly less in front than in the back to somewhat stick with LR recommendations, but with the weight of my truck, and my BFG E-rated tires, not sure if that's needed. Once I had the Kaymar in the back, then the rear will become about 300 pounds heavier.I've been running the same pressure all around at 44psi for city/highway driving.
However when off-roading I go down to 36/42...
Is there a reason for sticking with the same pressure all around even though LR recommends to run lower front...
Thank you
PS I will try the 40 you recommend for on road driving. What do you recommend for off-road?
