Is LR117568 the correct thermostat for a 2015 LR4 3.0L w/supercharger?Did they put in the right thermostat?
There's so many different part number. Are there options for different opening temperature?
That's the same part # that I put in when I replaced.Is LR117568 the correct thermostat for a 2015 LR4 3.0L w/supercharger?
They will get hot, but typically they’re only gonna get hot when you’re reallyI also noticed the supercharger cooling loop never gets hot. Those are the small semirigid coolant pipes just above the supercharger air cooler. The auxiliary radiator also never gets hot. I can hear the supercharger auxiliary electric pump turning ON when I open or close the driver door. Looks like the electric pump does not run all the time.
Can other LR4 owners confirm if the supercharger coolant pipes and supercharger radiator get hot ?
