2016 LR4 Landmark SCV6 Engine Failure at 65k. WWYD?
f1racer328
AZ
My understanding is when the crossover pipe catastrophically fails the coolant level sensor doesn’t have enough time to issue a warning.
Longtrail
Ann Arbor
This is my understanding; I did recently receive a low fluid warming on my 2012. I plan to tackle the timing chains, crossover pipes and coolant pipes later this summer...
Al Pizzica
PA
Super bummer and I feel your pain as I am in a somewhat less crappy position. 110k and I know the chains are loose. I have it parked up while I think about it.
I was considering donating it as a 5th option but I don't even know if that would affect my taxes with the new standard deduction. In your case there is some ability to say you donated a $25k truck to charity.
teleskier
Supporting Member
Supporting Member
Austin
The technology to warn us is there, but not implemented. Its all I can conclude.
TonyInIdaho
Coeur d'Alene, ID 83814, USA
I have a 2014 Lr4 3.0SCV6. I love it, but, I have found that under heavy loads it will use oil. If I tow heavy or drive a prolonged amount of time at 85 MPH it can use a qt in a day (around 500 miles). Under normal driving it is a qt between oil changes. I change the oil depending on conditions every 3,000~5,000 since I purchased with 83k miles in Jan '23, its now at 110k. I know the previous owner had all the service done at the LR dealer with oil changes between 6k~10k‍
I am also curious what was done with yours.
Pagoda
Is there an option to put the 4.4 V8 into the LR4 and replace the 3.0L?
f1racer328
AZ
Considering the amount of ECU changes/configuration updates you need to get the supercharged 5.0 into an LR4, it would be nearly impossible.
I know someone has LS swapped an LR4 too, but once again, project car, not daily driver.
So yes it is possible, but not practical.
