P2187, P2189 2015 LR4 HSE
Felix Orfila
USA
I'm getting my engine motor light on. When I get to my mechanic, they use a code reader looking for codes P2187. They told us about System Too Lean at Idle Bank 1 and 2. First they tried to erase the code and Engine motor light comes off but Eco mode light comes on. After few minutes Engine motor light comes on again.
scott schmerge
Charlotte, NC
possibly a vacuum leak. Check pcv valves.
Robin Parsons
Austin, TX
I had the same. Replaced OCV valve, and also all 4 O2 sensors (105k. Snd they were cheap). Eco mode works again, and 2 mpg improvement.
2011LR4LUXAA
San Jose CA
Did this happened when you were low on fuel? I got those codes when I was low on fuel and used the GAP tool to prime the fuel pump and codes when away and never came back.
