Showoff Your LR4
backcountryLR4
Utah Backcountry
Parent's came to visit and took them down to Moab for the weekend.
Hit 80 degrees yesterday for the first time of 2017 and went hunting for snow up in the mountains.
Ended up coming across a broken down F-150 up near the top of the trail and did some of my first towing/recovery with the landy. Hooked up the Ford and towed him up to an open spot(which happened to be a natural gravel pit) to where I could turn him around and get him pointing down hill. I expected to notice that I was pulling a 5,000 lb truck at 7000 ft elevation up a trail and through a deep gravel pit. I couldn't even tell he was there...
This was all after a Jeep over-heated trying to pull him. On-lookers even commented how effortless it was.
Haven't even had my LR4 for 6 months, but I like it more and more as time goes on.
Shot from last night prior to helping out the Ford:
ProTonez
Philadelphia, PA
Thanks XL,
Well I would love to mod it. I should have taken a look at this forum before I decided that. The first thing is I need new tires (after less than 20K miles)!!!. I wanted to put on some beefier tires like Nitto Terra Grapplers, however I have 20inch rims and that doesn't leave much room unless I get a lift kit. I'm looking for the most width I can get with a cool look. Tire rack guy said 265's (265/50/20). Currently I have 255. You have any insight there?
jwest
Seattle WA
Thanks XL,
A. There is no such thing as a "lift kit" and the so called 'rods' are simply cheating while providing nothing truly changing the available height already designed into the system.
B. I had wider wheels than the lr4 stock 20". They were RRS SC 'Stormer' wheels with 285/50-20 and they barely fit. You can hammer/bend back the outer lip of the UCA if it does contact the tire. Nextcsize fit sure would be 275/50 and of course 275/45 but these are all geared toward the wider wheel.
C. If you want to stick with a tire that actually fits your wheel in an ideal proportion, probably that 265/50 or 275/50, you could get it flush with the fender by adding a 25mm spacer from H&R. I wouldn't recommend their 30mm as it could start to push the tire into the tight clearance spots while turning, which even the waste of money 'rod mod' doesn't really remedy. The H&R spacers are very well made. I have both sets.
Verify your wheel width and offset first. Also, do you have a full size matching spare ? If not, you can't use the temp spare if you've changed the diameter of the running tires. You should be getting a 5th wheel and matching tire for the spare.
backcountryLR4
Utah Backcountry
You use low gear to tow?
Uhhh... nope.
Should I have?
I'll be honest, the LR4 is my first truck and don't have a ton of experience towing. Watched bunches of recovery videos so I can at least be safe and responsible. This incident wasn't really a recovery, we wasn't stuck. Just couldn't move under his own power. He simply needed to be pointing downhill so he could roll out of there.
