Prepping for SCV6 120k mi service
ebp02
ATL
@Longtrail I’m still up in the air on switching to the upgraded metal parts for everything; I haven’t seen a lot of feedback on here for those that have converted. I probably need to scan the jag forums to get more results and see which brand is more popular (I think there are a few now)
Chains still feel tight using the finger test through the oil filler; 5-7k mi oil change intervals since I’ve owned it at 50k.
I may throw on some pulleys/tensioners while it’s apart, but I’m not too terribly concerned since those can be accessed without SC removal. The biggest concern is what should I do at this mileage that would require SC removal again within a short timeframe
I did the front cross over in metal and had to bore out the lil coolant plug ****, did the rear cross over in metal and decided to swap out El cheapo sensor on it for the OEM one, the China sensor was press got and never went back in the same, the oem one leaked so I had to add coolant safe rtv. Later my front hose started weeping at the SC plastic y so when I changed that I added the aluminum thermostat, I tried changing the sensor/ probe for the oem one but it was a different diameter. It's been 15k since the thermostat and had no coolant issues.
q5sys
MD
JLR makes metal pipes now. I have a set I’ll sell you, I bought them thinking I could make it work on the NA motor but yea way different. I don’t think the dealer will accept the return. Not my photo but this is them.
I noticed those in a few SC V8 Jag tear down images/videos, but I wasnt sure if they were actually OEM, or just a much higher quality fake. Some Chinese parts are very convincing and its not like It'd be hard to 3D scan the OEM part which would capture the logos and such (or import the point cloud and add the logos in a CAD later).
The reason I was unsure if they were legit is that, that the rear manifold is still plastic on those engines in the teardowns I've seen. Seems odd JLR would have realized Metal was better for the front manifold but not the rear one.
If you bought them from a Dealer, what dealer was it? The dealers around DC don't seem to know anything about metal coolant pipes when I called and asked.
Whatever dealer will sell them to me will get my money.
GenesisMK
