LR4 Steering Sounds
nolift911
So I have this exact noise - did anyone get a final fix for this?? It sounds more like it is inside the truck, right at the steering wheel where it mounts - something is rubbing.
Cogs4x4
Yup...
After about a year of complaining got it fixed..
Steering gear ) rack not getting proper lubrication after a tsb that replaced steering gear.
Greasing boot / replacing steering shafts in column did nothing.
Simple Power steering flush and issue resolved.
Had nearly identical sound in a newer ford vehicle recently..
Same crap... Dealer looks at everything but replacing the leaking steering gear..
Wait a year gets worse leaks from both sides, have inspected by a Indy shop... Agree steering rack is leaking
Replaced flushed new rack as part of install . Sound gone.
nolift911
Interesting thanks - it just sounds like its right behind the steering wheel, will have to get mine flushed to see if that fixes it.
viper_iii
Did you check videos at start and compare?
I checked even got things replaced on the high side...
Sound / vibration is transmitted up the column.. makes it sound like it's right at the wheel...
Since that LR4 I've had 2-3 other vehicles with similar sounds - those were also tied to steering rack issues.
Had I known ~$300 would resolve wish had done (dinner? *** phone) sooner!
No longer have the LR4
Not interested D5 / Defender
Think the new Bronco looks better and more like the Defender should have looked.
nolift911
Yes I did its exact (thanks for the videos) so not doubting you - just seems odd since it sounds like it is right there.
Salanizi
Kuwait
I had the same sound coming from my steering column which i thought was from something rubbing (2015 LR4)
Flushing the power steering fluid with fresh CHF11s cleared it completely
