avslash
Very cool but I don't think you have a custom tire sizeThey don’t make a 275/75.... you probably have the 275/70 roughly 33”.
With the mods you have done, you should consider a 34” next. I have all the same mods plus the strut spacers.
I’m using the km2 in 34” 285/70-18.
Never mind, I forgot your on an lr4 and using those think spacers. FYI, H&R makes a 1” spacer that does what you need still while buying more clearance on turning and articulation into fender liners.
Ideally the most clearance for an lr4 without swapping brake rotors down to lr3 size is to use the Compomotive wheels which have very little extra offset. It’s just enough but gives up very little in clearances.
I actually have lr3 v6 sized factory rotors which allow factory 17’s. Some ideas for youndown the road.
Nice video ! I go out alone a lot and am too dang lazy to set up a tripod but I am now inspired!
You are correct. I "fat fingered" it. They are 275/65R18. About 32.1"
I know those Compomotives are the best. I have had them in my "cart" on multiple occasions. I just keep imagining beating the holy hell out of them, and their requisite replacement cost.
Hadn't heard about the H&R spacers. I might order one for research.
If I remember correctly, you have quite a bit of added weight on your truck, as well. Noticeable difference with the smaller rotors?
