lr4 fan clutch thread direction
Androomantoo
Olathe, KS
I can not get the fan clutch off to save my life. Bent two 36mm clutch wrenches. Air hammer is doing nothing.
Any other tips?
alldazed
ontario
How big is your compressor for the air hammer. My 1 gallon one won’t do it. I need the grunt of the 30 gallon but probably something in between will do probably.
Androomantoo
Olathe, KS
It’s only an 8 gallon so it probably doesn‘t quite have enough oomph.
Androomantoo
Olathe, KS
I ended up ordering this wrench set from Amazon and it took the fan clutch off easily. Highly recommended, but wear gloves because the edges of the wrench will destroy your hands.
UTMALL 2PCS Viscous Fan Clutch Spanner Wrench Tool Set for Land Rover Range Rover 4.2 4.4 TD V6 303-1142 303-1143 https://a.co/d/dot707c
