bcaese
- Joined
- Sep 21, 2009
- Posts
- 95
- Reaction score
- 0
Its probably easier to start from the interior inside, poke through, then pull it from the engine bay. Depends on your connectors. I always put the connector on last, and feed the wires through from the interior.
That does sound a lot easier
Can you see the grommet clearly from the interior when you remove the panel under the steering wheel?
- So remove panel under the steering wheel
- Poke small hole from the interior out
- Then run wires from interior out
- Then run wires through to the center console, where the switch will be
Please let me know if I am missiing anything else
