Engine Questions DII
K
kapaduch
This post was originally in another thread...
Sorry to ask again, but i have read a couple links about cleaning your O2 sensor, and cleaning your MAF sensor, do you think either of these could help, and if so, do you know where they are located, and what to clean them with.
Thanks guys,
Kevin P.
Monty
Not sure about cleaning the 02 sensor but the maf is just upstream from the airbox, has an electrical connection on it. Remove the airbox and you'll see a metal screen with the sensor behind it.
For cleaning the maf, I used some electrical contact cleaner that I picked up at Autozone, forget the name brand. Lots of dirt and crap all around the sensor and screen were cleaned off easily.
Slam
You can clean the MAF with some fast drying electrical cleaner from the computer store.
D
discomike
You can't clean the O2 sensors, when they are gonethey are gone.
mike J.
