crash data - cranks but won't start
lrovy
France
Great thanks for the link. No doubts, airbag and restraints need to be replaced. I'll try luck though with just airbag disconnected and as soon as will receive new one, will put it in place, same as restraint.
Thanks again for all help. btw. reading about 2.7l diesel - this one has still inertia switch. In Europe majority are diesels, these days 3.0 D4 and reading through some forums, seems like these do not "behave" same way and people could start them with SRS still pushing alarm to the dashboard. But these were built for European market and given different laws and even different schemes in workshop manual for NAS - that might be the thing... obeying some laws in US, hence my earlier question about laws.
I'll post update once will identify the culprit.
Thanks again.
lrovy
France
Thanks for everything and the links too! I'll come back with findings once I'll get it fix - hopes go it will be the suspected one.
lrovy
France
RCM Crash Data is cleared. Though big question is if any additional routines need to be run by SDD on RCM, i.e. re-programming or something?
The enginge doesn't start still, same issue as earlier. It could be linked to the fact that airbag hasn't been replaced and seat belt buckle pre-tensioner needs to be replaced too (it fired during accident).
But really? It does block the engine from starting? I'm getting more and more suspicious that there's something else, as there's no crash signal on the bus anymore hence weird to see that engine wouldn't start.
Next suspicion is also reported by RCM and some other modules like SODL, SODR report as:
active_network_configuration `?
Literally "`?".
Whilst other modules show 6006, 6008 or something more reasonable.
Active DTCs are:
B0001-13 RCM - Driver's frontal stage 1 - deployment control
B0002-13 RCM - Driver's frontal stage 2 - deployment control
B1211-13 RCM Driver safety belt retractor pretensioner deployment control
B1212-13 RCM J_14229_DTC_B1212
B123A-15 BCM Front left turn signal
B1D64-87 HCM Left headlamp swivelling motor circuit.
At the moment, airbag is disconnected as am awaiting for replacement and confirmed that buckle pre-tensioner has fired as well, so needs to be replaced.
Any thoughts/suggestions are more than welcome.
lrovy
France
Well... all replaced, no error codes, all nice and green - from the important ones.
Yet, it doesn't start still.
The only remaining is for the lamp, but hey, would this block engine from starting? My take is 100% no... but I could be wrong.
# only these are active
Fuel pump fuse has voltage. Checked with SDD and it shows low and high pressure, low was ~750kPa (from top of my head) and high was just shy of 20MPa.
Starter runs, but engine doesn't fire up...
Given no errors/DTCs... any ideas what it could be? Where to start next?
Ignition coils and spark plugs? Should there be an error if something is wrong there? But all of them would be bad? What else is needed? Pressure on fuel rail - seems to be based on SDD. So my take is check voltage/fuses again for ignition coils but then outside of checking physically if fuel pressure is there, what else?
It seems like next stop is at LR specialist unless you guys have some ideas? What it could be and escapes getting spotted by all the modules and electronics this car has? Hope it is nothing super $$$$
jlglr4
Northern California
So, you now hear the fuel pump when you turn on ignition (pre-starter motor)? The high/low fuel pressure you are reporting from SDD seems suspicious to me. Are you sure those are not just the trigger points for the codes? I don’t think fuel rail pressure at startup would be 20MPa. On my GAP tool, I can see commanded and actual fuel rail pressure. I cannot remember the actual fuel rail pressure at idle, but seems like it was around 6000kPa.
If you can confirm the fuel pump is working and rail is pressurized, then - yes, spark would next on my list. But, if you are getting no spark anywhere, I wouldn’t just be replacing plugs and coils. There would be some root cause.
Other things - make sure no airflow obstruction, make sure throttle plate/throttle body is functioning.
wannapreg
Ghana
please i am in the same situation and i need your assistance. how did you finished this job, what were some of the things that you did to fixed the problem or what did the LR specialty said they did..
thanks and look forward to from you
wannapreg
Ghana
I owe you a beer, at least!
The car is LR4, US import :) It spent its life in Texas, till now. In Europe it was 99% sold Diesel and these PSA (Peugeot design in LR starting with 2.7, through 3.0 and latest SDV6 in post-lifts have all issues - engine breaks after ~100miles or more). It's design issue. For this and couple of other reasons I went with petrol one and best option was to do US import - same path father went.
So, all US (NAS) spec applies. I only have workshop manual for pre-lift so it doesn't include SCV6 (v6 petrol super charged - AJ126), though it is castrated v8 (AJ133) ;) so probably a lot of logic applies. It says:
If the Supplemental Restraint System (SRS) outputs a crash signal on the high speed Controller Area Network (CAN) bus,
the ECM de-energizes the fuel pump relay to prevent any further fuel being pumped to the engine.
Knowing this and that RCM (which is SRS) outputs
B1193-00 RCM - Crash event storage - Full and locked
I've strong feeling that am dealing with software safety lock of fuel pump.
Relays are pulled out to the table and funny - it doesn't have the usual relay description of control pins and "data/power" pins. Will get father to check if relay diagrams are on the side of them.
The authorities - I thought that similar might be in US, but it might be different obviously. Do you know how is it in US re post-accident car behavior if it is allowed to block itself from starting after initial fuel cut off?
Thanks for detailed steps! Really appreciate it!
so finally, how did you got the problem solve, i mean this b1193
lrovy
France
The engine didn't keep compression - it had to be rebuilt and, well... cost was ~10k$ for everything. My mechanic took care of all and as I wasn't under pressure and car was prepped for my dad, it took a year + to get everything done as problem was also to find someone who can do that and do that properly (petrol engines are not that popular here for LR).
Other items I've fixed on the way was crash data though it was before discovering there is no compression, so not sure if it blocked anything. (feeling is that rather not as it cranked).
I'd suggest to check compression of all cylinders.
Good luck and hope it doesn't cost you that much as it did us.
wannapreg
Ghana
Well, ,my I got the engine changed because the previous engine got damaged, IN THE WRECK..
You mentioned that you had to deal with crash data, can you explain more on this ...
wannapreg
Ghana
I got the engine started after resetting the RCM with a good programmer, to clear the crash lock data ..
