ryan-in-oregon
- Joined
- Jul 7, 2009
- Posts
- 538
- Reaction score
- 3
Hum... not good. So what prevented you from moving? In my mind, this is a damn 4x4 and it should be able to move without a front half shaft![]()
Well the electronics get confused with one broken halfshaft. The transfer case Would lock only when it detects slippage. If the wheel won't turn it doesn't know that it is spinning. (abs sensor is on the hub and is also used for traction control) However I thought in rock crawl it auto locked the center diff. If it isn't lock you have three open differentials and 100% of the power will go to the wheel with the least traction (ie broken).
