60k Service Costs/worth??
Bluebird
Check the manual for what is required by the miles. Coolant is 75K I think. Maybe 100K
Yes, you should check on that, I wrote this list up for D1's and D2's, but it gives you something to work from and all the parts will be under $325 or lees depending on if you need wires.
jpljpl
Hi JP
I use Rover Specialist shop in Dumont, NJ.Here is their number- 201 385-0333.Ask for LEE.
Thanks! I'll add this to my address book for future reference. No specific need for them now, good to know about a recomended local indy though.
JackMac
Found this 2006-2008 LR3 Maintenance Schedule online from LRNA which includes the 60K service actions: Clicky
drzjoint
thanks for the link. looks like just change the oil and air filters and check fluids and leaking. Wow not much realy done for the 60k looks like the 75 is the bigger one. I thought I heard guys were getting charged around 1000 bucks for the 60. that seems like alot if they are not changing more fluids.
allodial
drzjoint
drzjoint, I think you were looking at the KM and not the M section... the 60k "M" for miles has a long list of checks and services...
btw im having some suspension clunking/rattle when going over rough roads... maybe bushings or sway bar loose? any ideas?
ill be taking the truck in for service this Thursday for that issue and also 60k service... ill be sure to get a full rundown and post costs/service.
...idle along at about 3 - 5 mph and then tap the brakes abruptly. If it "clunks" then yes it's the bushings.
allodial
yeah it happens even when im backing out of my driveway down the little 2 inche curb drop off and braking... i kinda figured that might be it but wasnt sure with the LR3 having airbags and me not know **** about them....
any idea on if thats a warranty covered issue? or if not cost of fix?
i like to be semi prepared for the dealer visit so i can give them a yay or nay to services they try to **** me with....
Trynian
Should be covered under warranty unless they find a way to say you caused it like they usually try to do in my area.
