5x120 Trailer Hubs! Where can I get them?
m_lars
Utah
The LR wheels have a small lip on the inside of the center hole it can be removed and the wheels will mount on trailer hubs you can’t put the center caps on while the wheel is on the trailer but you can put them back on if it mounted to the LR after removing the lip. I ended up fabricating my own spacer only because of clearance issues with my fenders and tires (I had less than a 1/4” between the wheel well and tire so when on rough road the articulation would cause the tire to rub).
Yeah, I probably could have cleared the bearing cover that way, but the center bore of the wheel is smaller than my trailer hub diameter. Also, I didn’t want to modify 18” LR3 wheels in case I ever want to sell them.
