4WD System Question
TrinidadLR4
NE Washington DC
Hey gang,
Random question - on a 2013 HSE 5.0 with a 2sp transfer case, what type is the center diff? I know on the 2014+ models, if you don't get the HD package(and therefore don't have the 2sp xfer case), you get a Torsen center. But what about the 2010-2013 models? I have been seeing ads listing the center as a Torsen on these, and I know that ain't right. Thanks!
Nechaken
Colorado
I believe the service manual refers to it as an "electronically controlled multi-plate clutch"
Rover Range
Texas
Both the single and two speed transfer cases use a planetary type gear set.
The single speed transfer case has a 40/60 torque split, while the two speed is a 50/50 torque split.
ftillier
Portland, OR, USA
My HD optioned 2012 has an electronically locking center (and rear) diff, but I don't think the non-HD use a center locker so perhaps that's a Torsen.
TrinidadLR4
NE Washington DC
So the center is a torsen then? HD means rear locker(open otherwise) but I'm curious about the center. I know the front is open.
Nechaken
Colorado
I believe all 2010-2013 have a center locking differential and the HD package adds an electronically locking rear.
2014-2016, the non-HD has a single-speed transfer case with Torsen differential. HD package adds a 2-speed transfer case with a multi-plate clutch, as well as an electronically locking rear diff.
Nechaken
Colorado
Here's a cool post if you want to see what's inside.
mm3846
LI, NY
Wet clutch eLSD center diff with full lockup capability, not a Torsen. Not sure if the single speed is the same, it probably is just minus the low range planetary
park city
All righty then. 2012 newly acquired HSE with full size spare or at least a rather big spare; crawled under and saw only an "air" line going right into the top of the pumpkin; I suppose that could be a speed sensor too; but without an accurate build sheet which I cant seem to find does anyone know whether one needs to see the electronic switching motor on the later models; it would seem to me thats a yes, right? However, it must be limited slip because I experienced that on snow.
msw777
