I suspect a faulty ECM on my 2015 LR4. I have the following symptoms:
Any comments, recommendations?
- Overheating. I suspect the ECM is not energising the electric thermostat. The upper radiator hose is never hot.
- Viscous fan is always engaged.
- No communication with the OBD socket. See attached picture. I have confirmed 12 volts on pin#16.
- The amber warning indicator light in ON. No engine light.
- Coolant pump
- Viscous fan
- Thermostat
- Electric auxiliary coolant pump
- Rear crossover pipe with an ECT1
- Main radiator
