I think different people may be using the term "bi-xenon" differently in this thread.
I have a 2012 with the HID headlamps. The Xenon burner has a moving reflector/shield. When I turn on the high beam, the shield/reflector on the Xenon lamp moves to give a higher cutoff, AND a separate halogen high-beam turns on.
The attached jpg shows the movable shield referred to above that moves out of the way when high beam is called for. That then means you have high beam as well as low beam coming from the single Xenon bulb.
The bi-xenon shield setup is not a good design for "flash to pass", hence we have the separate halogens for that function and to provide additional illumination for high beam. It is a pretty good set up and not something I would fool around with too much.
To see how all works, park in front of a reflective window at a shopping centre and play with the high and low beams and flash to pass.
As to the colour of the light, Land Rover, BMW, Mercedes, Audi etc use the 4300K colour as they think that gives the best illumination for what is called definition - means you can figure out what you are looking at.
The other extreme is the blue lighting in the after hours clubs, (and early Mercedes), where you can see a person but not figure out boy or girl - crudely, that is what a lack of definition means.
A LED bulb that is 6000K might be bright but that does not mean you can determine what it is that is illuminated.
