[QUOTE="scott schmerge,
2010 LR4 @218,000 mi
glad to see another high milage LR4, have you had any major repairs or abnormal issues? ive got 170k now and at pricing out all the stuff I need to change out
transmission service which I totally forgot about at 150k( on first starts in the morning it seems to have a slight delay shifting but I don't think its anything serious, goes away when warmed up)
air bags and AMK compressor upgrade(with valve block seal rebuild)
and buying the iid gap tool
so all in for almost 2000
[/QUOTE]
Apologies, fat fingers and didn’t notice. 118,000 on the clock.
I just did a full transmission service and it cleared everything up. If you’re doing the trans fluid, go ahead and spring for the pan from AB, do mechatronic bridge and four seals along with the solenoids and mechatronic electrical sleeve. I used Mercron SP fluid ($80 for twelve qts vs $300 for lifeguard6). Transmission shifts like new...
This truck is amazing and still has a lot of life left in it. I fully expect to make it to at least 200k.
Next big maintenance thing on my list is timing chain tensioners. They’re still quiet and no codes, so fingers crossed it will hold a bit longer. Planning to get another 15k before they get done.
