- Joined
- Feb 8, 2011
- Posts
- 3,401
- Reaction score
- 93
Just a quick update on my TPMS journey...
As many of you know, I have the 18" Compomotive wheels with 265/65R18 BFG A/T KO tires on my LR4. I had the four tires installed without TPMS because the stock TPMS would not fit (even with new seals, etc.). At first I thought it was only because my local independent Land Rover garage did not have seals, but it was confirmed by two different national tire places.
I ordered one TPMS unit from TPMS Direct to test on the spare wheel/tire and it fits perfectly. So, I ordered four more for each wheel/tire and will have them installed in the next couple weeks. Hopefully they will work once I have them installed and turn TPMS alert back on with my IIDTool. I will also turn off the TPMS alert for the spare tire - I don't plan to stow under the truck.
I know a few of you also bought these same TPMS units and you did not need to calibrate or anything. They just activated and worked. I noticed in my owner's manual that it states there is a TPMS setting in the vehicle service menu, but I don't think that is part of the NA LR4 (I don't see it in the menu).
So, for those of you going with the 18" Compomotives, my stock 19" black-design wheel TPMS units did not work. I am not sure if this is due to the black design package (since the units are black), but there is no way to create a proper seal. This was also confirmed by someone else on the forum. I know a couple people have used the stock TPMS from their stock silver wheels - not sure if these are different or not? The TPMS from TPMS Direct are Land Rover OEM and seem to work great - will let you know if they activate just fine.
-David
-David
