TPMS Reset Button
LandRover0415
New York
Hi, i have a 2012 lr4 Land Rover and about 2 months ago the TPMS light turned on. I’ve taken my car to the dealer and the pressures in all the tires are good. I’ve bought and changed all 4 sensors (also original), and those are good as well. I looked up on google and it said there’s a button located under the steering wheel to reset the fault. I’ve been neck deep under the steering wheel and cannot find this button. Does anyone know where exactly it is located? Please let me know, thanks.
Rover Range
Texas
No reset button.
At least not on the North American models.
Check fuse F1 5A in the fuse box behind the glove box.
ftillier
Supporting Member
Supporting Member
Portland, OR, USA
When you got new sensors, did you make sure they are the correct frequency? The earlier models had TPMS sensors at 315MHz, while later models used 433MHz sensors.
