- Joined
- Feb 8, 2011
- Posts
- 3,401
- Reaction score
- 93
I suspect that will be the case!Dave, once you out them on the car with new tires you will not have any buyers remorse! As to the tire, I noticed a difference between Brandon's and mine when it came to loose sand. Not sure if it was size or tread though.
I just need to figure out tires. I really like mbw's set-up and he said that there is no rubbing at all in stock or access mode (I don't use the latter very much). He can also stow away the spare and just had to deflate it very slightly. I know he removed the heat shields, but I don't remember if that was necessary - have to look back.
I bookmarked a few threads on here about TPMS and tires, so I have a bit of time to do some research. I also want to look back at Umberto's truck to see again what the satin black Comps look like on the black design package. I do love my 19" split-spoke black design wheels, so I plan to keep them along with the Contis on them.
-David
