suspension
puckball55
south florida
my suspension shifts positions by itself periodically and i try to lock it in one position. does anyone else have this issue?
djkaosone
'11 LR4 HSE LUX 5.0L V8
SoCal
It self-adjusts every once in a while. If you're trying to lock it into position for an alignment, the Gap IID Tool has a feature on it that puts it in "tight tolerance mode" just for that specific occasion. For all else, you can simply pull fuse F26 for the compressor and F3 for power to the rest of the suspension.
puckball55
south florida
it dropped to bump stops. had to replace two front struts and air compressor. afterwards i drove it 950 miles to lex ky and back and suspension never waivered. however i am now experiencing front end shimmy on braking.
Check your lower control arms. Do you have any clunking when tapping the brakes quick?
dimitricourmousis
