Fuel Feed Issues 1997 Disco
wolf
This one is mainly for Joey but if anyone else has some ideas please add them in!
Hey Joey;
Ok - so do you remember my interesting starting issue (i.e., turn the key until pre-ignition lights come on dash array - wait a two seconds then crank = starts right away [otherwise no start if you just stick the key in crank and try and go])? Here's the latest installment on this: i.e. in my pursuit of instant and proper engine starting I did some more research and decided to change out the tps and the fuel regulator. Procedure and results are as follows:
1.) disconnect power supply (battery)
2.) remove annoying rear engine coil paks so that one can get at fuel reg bolts
3.) bleed off fuel pressure in fuel rail via shrader valve
4.) r&r fuel reg
5.) r&r tps
6.) re-connect coil paks assembly
7.) re-connect power supply (battery)
8.) try a normal instant start on the engine
9.) no instant start so try pre-ignition pause routine - engine starts
10.) idle rpms go to 1500 and stay there for a while
11.) stop engine to reset and start again same thing
12.) rpms slowly come down to 900 but not to the standard of 700
13.) smell of gas between restarts but that goes away (i.e., does not happen if I go through the enhanced pre-ignition start routine)
14.) our old friend the p1179 code returned briefly (this dissappeared after a thorough cleaning of the K&N air filter and filter is still clean right now)
15.) a small increase in acceleration power is noticeable
16.) I still get the occasional catalyst efficiency sub-standard codes - i.e., PO430 & PO420 (I recall that you have got these a couple of times) - but this does not occur regularly or even that often
17.) gas mileage is really in the toilet right now as well (thus prompting my latest attempt to fix starting issue)
Previously, we had discussed the possibility of the fuel pump going soft but, if you recall, the pressures were good.
My other speculations would include: r&r stepper motor; r&r fuel temp sensor; r& r fuel pump?
One final query = how do you reset the "closed throttle voltage" for the tps (something my British LR fault code manual calls for when replacing the tps)?
That's all for now;
Wolf
Sorry for you issues wolf....
TPS reset is either via Testbook, or I have heard you can disconnect the ground from the battery for 15 minutes or so and this may clear the issue there.
Since IIRC you have the powerchip as well, the catalyst codes are sadly normal but not often or regular.
I would call powerchip and mention the starting issue since this happened after the ECU upgrade correct?
wolf
Hi Joey;
Thanks for the fast reply;
Ok - I'll try the 15 minute battery disconnect for the tps - see if that works.
Good idea on the PowerChips folks - I'll give them a call (i.e., I think we get three years warranty on these)
I'll let you know how this develops.
thanks again;
Wolf
Disco2TrailEdit4
