land sedai
UAE
LR2 HSE | 2012 | 3.3L Petrol Engine
Issue 1:
1. I just put on my key knob and pressed only the start button to turn on electronics only, Not an Engine Start.
2. From the Engine bay I heard some noisy sounds (Video link attached). Is that any sensor or Fuel pressor controller or any other?
Can anyone help me with this?
Issue 2:
First attempt not even engine crank, after few attempt Engine crank for 1 or 2 times then next attempt Engine starting.
Battery is good. Sparkplugs are very new and good. No error codes. No engine light. All fuses are fine. after the engine starts vehicle runs well, no issues. but once I did Off vehicle then same issue begins.
I doubt it could be fuel line or FPR or something else.
I checked data stream by my OBD 2 device.
Before Engine starts FPR 0 PSI
After Engine crank did not start FPR 30~40 PSI
After Engine starts FPR 60 PSI
After Start Vehicle Move FPR 54~55 PSI
After Stop FPR 30~32 PSI
What could be the Issue and reason? How can I solve this?
I'm a new Land rover driver now trying to fix myself. I highly appreciated your help. Thanks.
