V8 Disco poor starter / rich running
Slam
Supporting Member
Supporting Member
A letter I received today....
I don't know if you can think of a common fault that would cause my son's 1995 3.9 V8 Discovery to fail to start. We have tried everything we can think of (including borrowing a Testbook system) to cure the fault(s). If we add a jump battery and really crank it over and over eventually it will start and run, but the CO reading is too high (2%approx) and it runs "lumpy". We have tried new plugs, rotor arm, distributor cap, ignition module, fuel filter, checked fuel pressure, checked the ignition timing, checked for air leaks all around the intake and even tried a new filler cap. Without the jump battery the engine will crank ok, but usually fires once or twice then refuses to start. We suspect from the readings on Testbook that the injector opening times of 2 to 3 milliseconds means the engine is overfuelling and flooding the spark plugs. The local Landrover agent here in the uk had the car for weeks, fitted a new coolant temperature sender they said was faulty, and then said it needed new Hego sensors because it wouldn't start, but several other technicians said this was nonsense, as the Hego sensors don't do anything for about 20 seconds after the engine starts. When the car is running the Hego O2 levels do vary from approximately -16 at idle to 0 at fast idle (say 2000 rpm). They don't go positive, but if the engine is running rich we wouldn't expect it to? The car had been running rough just before it let my son down, and had always been heavy on fuel, but he thought that was normal for this car. An ex Land Rover technician has checked the fuel pump for blockages etc and checked all the things we had already tried but to no avail. He also said the Hego sensors would not prevent the engine from starting. Do you have any other suggestions we could try?.
Yours hopefully
What do you guys think?
Moose
Leaking injectors are causing a flood. I'd bet $0.25 on it. :biggrin:
P
pfb
bump for more opinions...
How often do LR 3.9i injectors fail? It seems like many parts "fail often, cause problems often", and other parts almost never fail.
Best source for a set of injectors?
J
JackUnion
I think that I'm with moose on this one, they are not exactly common to go but I have changed a few!, best to do a leak down test on them and find out for sure. They are not cheap from LR but as they don't go that often I'd plumb for the good old used route as the chance of buying a duff one is quite remote.
P
pikasso5
Leaky injectors?
Now, would one or two leaky injectors cause it to not start and flood? Or would most or all of them have to be leaking? Seems odd to me that all 6 or 8 injectors would fail.
P
pikasso5
Gas
One idea that's kept mine starting is that I threw in some regular oct. gas. Apparently they over-octane in the winter and in some cold mornings, they have a hard time igniting.
B
BillHurr
Guys, thanks for your inputs. I originally posted this one under "Ulitimate off-roader" because it had been "off the road" for 18 months! I eventually traced the fault to a stretched timing chain which had allowed the ignition and valve timing to be out by enough to make the starting difficult (to say the least). I found this information on a website here in the UK (rpiV8.com) and they have a wealth of useful stuff covering everything on the Rover V8. The Disco is now running great, hope this helps?
