Terrafirma Swingaway Tire Carrier Issue - Loose Wheel
CPalacay
Woodinville, WA
I just installed a Terrafirma tire carrier on my LR4 and I’m running into a really interesting fitment issue where there is still play in the wheel even after I’ve tightened down all 3 lugs onto the mounting plate. I’m running a RR wheel with a 47mm offset, so that has more material than the stock 53mm yet I can’t get the lugs to tighten the wheel firmly onto the carrier.
I’ve chased the thread to make sure the powdercoating wasn’t the issue and I’ve even taken a wire wheel to the threads for good measure. Anyone else run into this issue before? Are my studs too long? My initial thoughts was to throw a 5-7mm spacer to solve problem but I haven’t seen issue come up for anyone before.
-Christian P.
djkaosone
'11 LR4 HSE LUX 5.0L V8
SoCal
How far does the wheel stud stick out?
Just get some m14 washers and m14x1.5 nyloc nuts.
