Sunroof? Leaking.
theskittleman
Hi all,
I've checked around a decent bit re sunroof leaks. Seen a few threads but nothing that's quite my problem.
I have a 2005 LR3 HSE that is leaking along the passenger side B pillar. It's both on to the floor and dripping through the seat belt opening.
Any ideas? Just a sunroof leak?
GSMblue
I had a similar leak, turned out the glass roof was installed without enough sealant in the corners so water was getting in. Do you have the glass roof? Was it ever replaced?
If I was you, do the normal drainage tube check/compressed air clean/upgrade to new style tubes before doing anything else. When you have done that, report back here :)
theskittleman
Do have the glass roof, it was never replaced.
Already on it. Thanks for your suggestions!
Any info as to removing the roof?
GSMblue
Removing the glass roof is not something I would want to do! If it has never been replaced it is unlikely to be your issue.
The glass shop that ended up replacing mine tried to save it, but it broke in the process.
Trynian
I believe the rear sunroof drains run through that area
