REAR DIFFERENTIAL PROBLEM
djatkinson
Ironically, my indie shop recommended a local Aamco tranny shop that has had good success and positive feedback working on this issue in the Rover. I'm not sure how they would handle scanning the vehicle to make sure there aren't unrelated systems generating codes because of this system, loose wires, etc. Maybe I should check that shop out...:call2:
olabodejegede
Hey Mate, did you eventually solve your Rear Differential problem? Most times just getting the actuator motor out from the assembly and servicing it solves the problem. You also have noticed a fault on the dash screen "TRANSMISSION FAULT, TRACTION REDUCED" immediately when you start or switch off engine.
Take motor out, hit with a wooden or rubber mallet while you try to feed with power from battery manually.
Replace the serviced motor, change the differential Castor Oil(if not replaced in a long while) and get someone with SDD or JLR IDS to reconfigure rear differential module. You should be fine if not replace Motor.
Also take note of a Fusible link fuse 40A Power supplier in the Battery Fusebox and also there is an ignition supply fuse(No 24) in the passenger side fusebox, check if they are still intact.
I have a diagram of the Electronic Rear Differential illustration attached.
Good luck
  • ELECTRONIC REAR DIFFERENTIAL.pdf
remember5
Attached is the section of the manual dealing with the diff lock motor, I haven't even looked at it so not sure if it will help or not.
  • differential locking motor (51.05.03).pdf
