twoboarders
- Joined
- Feb 28, 2015
- Posts
- 54
- Reaction score
- 7
First off, I have been a member here for 3 years and can't thank all of you enough for the insight and education. That being said, I'm moving out of WA in April and don't intent on taking my LR3 with me. After hundreds of hours of research I'm leaning towards an asking price of $8,500. I see prices all over the place and would greatly appreciate any suggestions you think is a fair price. Obviously I'm bias.
Attached a few pictures so you get the gist of condition/look.
5 year repair history below. All completed at the Land Rover dealership.
01.26.18 Oil Change 137,007
08.31.17 Oil Change 132,437
01.14.17 Oil Change 124,945
07.16.16 Oil Change 109,316
11.23.15 Oil Change 109,316
09.03.15 Oil Change 105,067
03.06.15 Oil Change 97,364
10.03.14 Oil Change 89,929
03.03.14 Oil Change 82,562
08.01.13 Oil Change 75,188
Brakes
07.01.16 Front and Rear Brakes (Pads, Rotors, Sensors) 116,574
03.03.14 Rear & Parking Brakes (Pads, Rotors, Sensors) 82,951
10.09.12 Front Brakes Pads, Rotors, Sensors 65,010
Transmission, Transfer Case, Differentials
08.31.17 Front Differential Fluid 132,437
08.31.17 Rear Differential Fluid 132,437
11.30.16 Major Transmission Service 123,353
08.24.16 Transfer Case Fluid 119,550
11.23.15 Front Differential Fluid 109,316
09.03.15 Rear Differential Fluid 105,067
05.22.15 Transfer Case Control Module 101,274
08.01.13 Front Differential Fluid 75,188
08.01.13 Transfer Case Fluid 75,188
Repairs
01.18.18 Primary, Secondary Belts (2) Tension Pulleys (2) 136,121
01.11.18 Installed Lucky 8 Lift Rods 136,121
02.17.17 Cleaned ABS module pins and connector terminals 125,848
08.24.16 Mount and Balance 4 New BFG Tires 119,550
08.24.16 Replace PCV Valve 119,550
07.29.15 Front Height Sensors and Jumper Wires 103,474
06.19.15 Repinned wiring at ABS module 102,158
06.05.15 Wiper Cowling 101,925
05.22.15 Wiper Cowling 101,274
05.22.15 A Pillar Repair Kit 101,274
05.22.15 A Pillar Trim Clips 101,274
05.01.15 Chaffed wire on rear frame. Wiring Kit 100,747
03.28.15 Front Diff Vent n/a
02.27.15 All Terrain Switch 96,569
02.20.15 Brake Light Switch 96,464
02.16.15 Brake Light Switch 96,004
01.06.15 Alternator 93,370
10.03.14 Spark Plugs 89,929
10.03.14 Replace Both Lower Control Arm Bushings 89,929
10.03.14 Thermostat Housing, Antifreeze, Valve Air Bleed 89,929
06.14.14 Starter Motor 85,926
06.06.14 Battery 85,926
03.03.14 Adjust A Pillar Posts 82,562
12.31.12 Mount and Balance 4 New Tires with Alignment 67,662
11.07.12 Throttle Body Cleaning 65,694
11.07.12 Replace Mass Air Flow Sensor 65,694
10.26.12 Replace Thermostat 65,010
Brakes
Repairs
