gsxr
I'm going through this right now, after a year or two of intermittent "only normal height available" messages. Similar symptoms with the compressor "working hard" after a minute or two running. IID tool shows fault code C1A20-64(6C), "Pressure too slow filling". Compressor and motor temps climb to 100-120°C and pressure struggles to hit 250psi.
I removed the original Hitachi and tried replacing the desiccant beads in the drier (old ones were not really bad, which surprised me) but there was no change. Exhaust valve rubber looked fine too. Couldn't find any significant leaks either. Gave up and ordered a new Genuine Hitachi from RM European, $575 delivered... arriving today. Anything you find in the $200-$500 USD range is going to be fake "Hitachi-type" junk, don't get suckered by the low prices.
I'll post after I get the new one in hand, bench test compared to the old one, and get it installed. Hopefully by tomorrow.
As you'll find in other threads, if you have an original Hitachi and change to an AMK compressor, you must also replace the control relay, cut pipes and use splice joints to connect different pipes, and possibly reprogram the ECU as well. You also have to try and find a complete AMK kit that includes the plastic enclosure which I believe is also different. I didn't want to go through all that hassle as I haven't heard anything about the AMK being any more reliable/bulletproof. (?)
If the new compressor doesn't fix the problem, I'm gonna be grumpy.
