Johnson Rods
- Joined
- Feb 2, 2010
- Posts
- 153
- Reaction score
- 15
In the end it really comes down to what you want to do with the vehicle. For most Johnson Rod users they want the 2.5 inch lift full time. Typically, they want to get away from the "soccer mom" look of the stock LR3 and want to have something that looks a little more aggressive with the lift and larger tires. The issue of ride handling on the freeway has not been a compromise or problem that anyone has complained about. In fact, the most common feedback is how surprised they are on how well it does handle lifted. It's true what you say that a lifted vehicle is not stock and will ride slightly different lifted but that has really been a non issue. Since the LR3 was introduced, thousands and thousands of Land Rover owners have lifted their LR3/4's, Sports, and full size Range Rovers. I don't see that trend stopping because of the IID tool. In fact, the trend is leaning toward purchasing older Land Rovers and using them as secondary vehicles for weekend fun, hunting, trail riding... Typically the Johnson Rod lift is the first mod they do in the process of changing the look and function.
Those who like to use the IID tool generally like to ride more at the stock height and don't plan on using max lift full time. The average max lift for this system is around 1.9 inches and sometimes less. The IID system costs a lot more but has great utility. I have also seen Johnson Rods and the IID tool used together when the tool could only provide 20 mm of lift. The tool is then used to adjust to the desired height taking into account the Jrod lift. Can't deny that the IID tool has its benefits. It's good to have options depending on what you want to do with your truck.
