largest tire with no lift
Dinfung
Vancouver, BC
That is good info. Which spacer did you run the rims with?
yes, running 1" spacers and no issue running normal height, no rub at all if properly aligned. If the alignment if off, even slightly, you will have rub either driver side or passenger side, depending on which way the alignment is off. it will rub without spacers.
Matt Taylor
Seattle
Has anyone ran Toyo Open Country A/T 3's at 265/50/20 or 275/55/20? Does anyone have any experience with Toyo's? Good, bad? Appreciate it!
KB_garage
ATX
This thread was extremely useful in helping me select a tire and deciding if I wanted to deal with rubbing or lifting, etc. In the end, I went with the Cooper discoverer rugged trek 265/50R20. For anyone like me who may stumble upon this thread, these do not rub on a stock LR4. I can't thank everyone enough who participated in this thread. I read it more times than I care to admit when I was deciding between tires.
