I got a problem...
D
discomike
An overhaul only if the seals in the valve body have hardened too much, other wise it is still worth the expense. I think it is worth spending the money on, only because it can reverse, to some extent, or slow the failure problem down until you are ready to stimulate the economy.
Mike J.
M
marc olivares
in my experience, when replacing fluid (and/or filter) in a high mileage trans, the highly concentrated detergent of the new fluid will typically wipes out whats left of the clutch plates. of the zf trannys the i have overhauled, the valve body pluging is a result of a wiped out plate.
what ever the case, replace the fluid with synthetic fluid. yes it's more expensive, but the break down temps are often 3 to 4 times higher.
cooler temps result in less wear.
beemer
Slip Trans
jcabrera, you have the symptom of a plugged oil pickup filter. When the oils cold it's thicker hence low or no flow, when hot and thinner more flow.This can lead to trans failure if you continue driving it. If it's high mileage the flushing will stir up a mess. Filter and top off, "Get-R-Done". Carl......o&o>....
