Bleeding coolant woes...... help needed!
Justin Allen
North Carolina
Glad to hear it worked. The pressure tester can be used to sort of “pre-bleed“ the system. Fill with coolant, pressurize it to 15-16psi, crack the bleeder valves. Will get some air out before ever bleeding. I did that, and bleeding literally took 5m. Had to get very little air out.
Stuart Barnes
Los Angeles
Sorry guys been away for a while.
Great news on getting everything bled.
One thing I want it put out there is that if anyone is in the la area then I have a vacuum bleeder tool and a shop compressor so hit me up if you need to borrow it.
stu
