air suspension -- dumb question
Easycool
Mesa, Arizona
Thanks guys. I got lost on the range rover forum. Need to find where I asked about the valve block. Not familiar with this site.
gsxr
Big Sky Country
If the entire rear is low, and not just one side or the other, it's probably the valve block--at least, that's what I would guess it is on an LR3/LR4. .
Ryan, if our 2010 LR4 is parked for 1-2 weeks, all four corners drop to the bump stops. But if it's less than 1 week, there's no significant change in ride height. Does this also sound like a valve block issue?
:confused:
morrisdl
You may have to pull out the leveling fuses (F26) to prevent the other 2 or 3 corners from following the bad one(s) down to the ground. The rear valve block is right behind the very dirty Left/rear air strut:
zTwsgtjRRmspAEXRGWwJxmxsFusOJLxGd7pwU2uNmG3Pj6FL6M7dG6bNpp5Zj9WcR0xL0TAzsnvperpIuZ43ViOPTR_PDtFDXn7K-IZhOI0xN8aWqkiZXRsfYfHX3zWBkKYquRGP2W4HnvWyKlzi1Df5bc-6iDVHdCspJHER9NAC05TDltfe6riFynOBYD9VEVB52GiAjjrJtNRr3goXVnnBQ2ti5bfnmOHtA3eytSIRgQ0-nOMEP7TkHFVts5MoUilBSuQxuEBK5bqdNZZ3srPTN_Lpg-7IeXCLp6WVqbC144DLOgTZTbeVDavzwbl1uzp2FrzzHoH94CWCyyBha1AEJvLNGiw1Gsf-6vlwzyeYPIUnwRz2oll7iY8cw79oDZp1LnV4A2OxWIifk7VuOGf14g8LwDud2R3yUJsSRTm8hQz5xOT2zZJ36pKLFQgggXjK3IRQhHiww3_QUOcmciWtHnD2evFCpVGBXnbs6Ka_CMgVvQtgTBP435jZCHU4M815P5WMfpLXaxJ64XEWCD2UvC4QlY2KpRu0T1ZmT9Og9QQa0NUR-Cztv3ARUgENqCnFuyAbQz9PLYJhXUdo0fbkwcbhS5LSOcyzW8nEdT092nwJuMf1laxyK3SghOs6pCrHC7-vPj-PO99ubuira5c37fU5zdoBSMZIvyO9J-jgp7yagZLAqOnX=w957-h1275-no
Replacement is pretty straight forward. Some people have had success rebuilding. SLOWLY disconnect the hoses - they are under high pressure.
