CRYA
Any update on which direction you went with switches? Djkaosone's solution is slick and similar to what we do with VW Westys, minus the Cat6, but not familiar enough with tearing into interior trim. Looks like his is basically the same solution as Spod. That BantamX at $900+ is crazy money...I purchased the ProSpeedUK Discovery 4 Front Spotlight Mounts with two TripleR-750 LazerLamps and I'm now in the process of...looking for a way to actually hook them up. I probably should've figured that out before I actually bought the lights, but here we are.
Since I know next to nothing about wiring or electrical systems I figured my best bet was the 4x4 sPOD BantamX. It seems to be a very popular (albeit pricey) option in the off-road community and is as close as you can get to a complete plug and play solution. However, I will say despite having a universal option it seems tailored (or at least more popular) for the Jeep/Yota crowd. I've tried to find out what my fellow Rover community uses in their trail-rigs, however I haven't found a good answer...or any, really.
Has anyone here installed a 4x4 sPOD on their Discovery4 and if so, are you happy with it? Where did you mount it in the engine bay?
If not but you have a power distribution set-up for your lights, what are you using?
Edit-Found a post by member Perseus using a Switch Pros for nearly half the money. This could be a great option. https://store.switchpros.com/sp-9100-switch-panel-power-system/
