Shreddera7x
Hi all
I’ve hunted high and low for answers before posting and managed to find one post on another forum with zero replies that matches the issues I’m having.
So, the other half has a 2014 Evoque, it’s 9 speed auto with the SD4 lump. She’s had many happy miles so far but last week it failed to start after her shift at work. She drove the usual 45-60 minute run down the motorway in the morning, then 11 hours later, it refused to play ball.
I drove out to see what I could work out with some tools and my diagnostic tackle. I was presented with various errors on the dash.
- Park Brake Fault
- Engine Temperature Indication Fault
- Gearbox Fault
Snap on Solus plugged in, cannot communicate with ECU. Cheapo Bluetooth obd with paid for app on phone, connects and gives fault codes related to ECU being none contactable. Export attached.
The main battery is a couple of months old but was at 12.1v. So, I slipped on the jump leads from my car. Still no joy.
The secondary battery just next to it was dead as a dodo so I disconnected it, and ran jump leads from another battery straight to the cables. Same problem.
I read that bridging the positive and negative battery cables (with the battery out of the loop) effectively used any stored energy and often solved these sort of issues. I’ve tried that also to no avail.
Has anyone had this sort of thing before or have any suggestions?
Video of the problem here:
- Park Brake Fault
- Gearbox Fault
