2013 LR4 Backup key cover cracked
nag24
Seattle, WA
Hi all, i have a 2013 LR4. The driver side door handle has an issue. the small plastic cover over the emergency keyhole is cracked. It can barely hold on there. I bought a replacement but it doesn't seem able to stay on. When I had the pre-purchase inspection, the mechanic (very trusted and competent LR specialist) quoted over $300 to replace it (i assume it was for the whole handle). Any advice you can give would be great- is there a reason i can't just simply replace the small $20 cover myself? it just won't stay on....
Rover Range
Texas
The part that the cover snaps on to is broken.
Replace that part and you will be good.
