Multiple Errors - Parking Brake, Suspension, Fun!
greiswig
SW Washington
I think raw voltage measurements on this system are dodgy, since the alternator does not work the same as an alternator from the ‘80s would have. It’s a PWM system, if I remember right, so that makes it difficult.
What the low voltage could be telling you is that the computer determined no charge is needed, because it’s a new battery.
Abram
Southern California
Hm! So even if the voltage is reporting lower than what it “should” be, it’s still ok? I have it connected to my charger right now and it shows 100% though when I started it up yesterday it was definitely reading lower.
I guess I just want to be sure it’s not gonna crap out suddenly. I do at least have a 4 year replacement warranty on the new battery
greiswig
SW Washington
I'm no expert on how the charging system is supposed to work. I'll defer to someone else with more knowledge here. But I believe that a really good, fully charged battery might not inspire the LR alternator to push out higher average voltages using its PWM system.
Abram
Southern California
That’s fair, I suppose my concern is that I don’t know what to trust as to whether the battery IS fully charged or not. I left it on my charger for 10 hours today and in the initial driving I was doing it was a consistent 14.5v, perfect, but then on my way back home it’s back to 12.2-12.7v
So either something is not working, or it’s just not activating the alternator as you said.
