Hey Folks,
The more I go down the rabbit hole with this timing chain job the more I realize the small nuances make a difference in overall project success... Today, I'm trying to figure out the procedure with the timing chain tensioners. Having watched many YouTube videos and posts on the web I'm seeing a pattern where if the tensioners are not properly prepared and installed it can lead to poor results. The Land Rover manual has this:
Other articles talk about clicking sounds, pushing the piston below the body of the tensioner, etc. Also, there are posts that talk about applying pressure to the guide when the grenade pin is pulled... On the long DIY Timing Chain thread it mentions this from the Jaguar forums:
Dave Tibbs also has this to say about the chain guide and tensioner that I think is a critical step.
- The Jaguar service manual is specific about a step I've seen other guides miss: after pulling the pin out of the tensioner to release the tension, you need to push on the tensioner blade enough for the tensioner to hit the ratchet stop - if you can push the tensioner back in, you haven't got it yet.
- When pushing on the tensioner blades in order to allow the tensioners to hit their ratchet stop, the service manual states to use considerable force - they are not ****ing around here. In the end I had to lever it hard with a socket extension bar in order to get it to ratchet. The "click" isn't as audible as the service manual implies, but you'll know when it's done as you won't be able to push the tensioner blade back.
I'm curious if others can shed some light on this procedure as details are a little sketchy. Here's the most comprehensive video I found, does this stack up with peoples experience?
https://www.youtube.com/watch?v=AgkDu4Y1A7w
Here's the Jaguar video:
https://www.youtube.com/watch?v=OdOgMGzLGeg
Thanks, Longtrail
Thanks, Longtrail
