stainless steel brake lines
I've had mine on since my brake conversion to fit 17s since 2017 and the SS brake lines have been good to me. BTW, here are the part numbers for Stoptech SS brake lines, Front: 950.22000 Rear: 950.22500.
It's a direct bolt-on. Super easy to fit and just make sure you bleed your brake system and have some Pentosin Dot4 LV handy. I ended up using 2 bottles since my old lines were dirty. Bleed furthest away from the master brake cylinder and work your way to the closest.
CPalacay
Woodinville, WA
I have the Terrafirma kits from Lucky8. The quality of the kits is very good and comes with all new hardware for mounting. My stock brake lines weren’t leaking, but definitely had some dry rot and cracking that I didn’t notice until taking them off.
You didn't do the rear inner? Or does the stop tech kit come with both inner and outer?
The rear comes in a kit with both inner/outer ss lines and hardware, full replacement to all rubber lines. The front is single ss line per side with hardware in its kit. Again, I did mine back in 2017 if I remember correctly.
