Timbo
Hi guys,
I've started the install for a set of Terrafirma HD steel rock sliders from Lucky8.
I went with these due to the "quick and easy" install process... that's funny
Anyway, I have hit a few roadblocks and was wondering if anyone else has gone through the install process and could please lend me some insight.
Firstly, the sliders come with a vertical 'fin' that tucks up underneath the frame of the car. However the 'AC' lines (I think that's what they are) run along the length of that frame and get in the way of where that fin should sit (photo below).
The obvious thought is to just cut the fin off along the length of the bend, but I'm wondering if this compromises the integrity of the slider? Also does anyone know how I would go about finding someone who can cut hd steel for me and then I assume I would need to re-powdercoat the cut (I'm in Los Angeles)?
Secondly, the sliders come with 22 bolts, washers, and nuts. I can see that the threads on the car frame line up to accept the bolts and washers, but I can't see what the nuts are for? It doesn't look like the bolts are long enough to pass through the frame, and if they did, I cant get passed the AC lines to fix the bolts. Are the bolts necessary?
Thirdly, I have removed the little yellow plastic clips that held the plastic moulding in place, but do I have to remove the little black rubber inserts, (photo below) or are they fine to stay in place and provide a little buffer between the slider and the frame?
Thank you so much for your help guys!
