No, my indy shop did it while he was down there replacing front brakes, all fluids, spark plugs, etc. He used the factory rubber bushings, as pictured.
Ah, it seemed like these were a upgrade from the aftermarket.
Do you guys grease the oem rubber bushing before installing them? If so what type of grease?
I was thinking the same. I am considering using poly just for the durability and not having to worry about them for longer.
Im at ~53k miles and haven't even done the front brake pads yet. (Rears once).. So this spring I will get in there and do pads/rotors and see what else is up. I think I am pretty easy on my suspension. Iowa roads, almost no traffic and very little stop and go.
Same here in MI, my brakes last forever compared to a lot of rovers.
Although it sounds like I do have a premature rear LCA bushing wear going on right now. I was thinking I'd see how hard it was to replace just the bushing only. Atlantic british has a video of doing it.
Yeah I think I would have been better off with OEM for sway bar seemed like a tighter fit, as far as control arm, time will tell I have about 15k on poly and so far so good but stiffer ride.It is s misconception to assume poly bushings will last longer. I have discussed this at length with three long time mechanics and a race car builder.
Which sway bar end links did you get? Not happy with the ones I purchased.This is what I want!. But I'm getting Meyle HD control arms instead. The ball joint is upgraded from OEM.
Already have the HD sway bar ends links and they're really nicely constructed.
http://sykes-pickavant.com/products/suspension-tools/bush-removal-and-installation/2338
Replaced my sway bar bushings over the weekend with orange polybush. Mine weren't as bad as Umberto's, rookie mistake though and I forgot to grease them...squeak squeak. Will try to spray with silicone or lithium grease before I remove again.
Heads up very tight space on driver side upper bolt, need a deep offset 18mm box wrench, ride quality seems unchanged from oem to poly. Where as with the LCA swap I would say the change was significantly more dramatic.
I meant to remind you, careful what you spray on poly parts as they can be destroyed by the wrong stuff. This was something the mechanic mentioned though I forget what fluid was so bad they disintegrated. It might have been as simple as ATF, brake fluid, or certain oils but I don't remember.
