To compo or not to compo
ivan gonzalez
265/65r18 I think that's the limit unless you want to get stuck if you get a suspension fault. I think this is king of the hill
Ryby
Nice! I had read some people are running 275/65 and then of course 285/60. Assuming the 275s would require some work though. I would maybe go with the 285s, wider stance sounds good to me.
ivan gonzalez
I vote for the compos too but I'm poor can't afford them. I like the look of the 10 spoke tho
I didn't think the LR3 18" wheels worked on the lr4 due to brake fitment issues?
ivan gonzalez
Even with 1.25 you do need to grind the calipers as I did and if you want no rubbing on the frame Horne you also need to cut and weld that too. I'm happy with my mods
ivan gonzalez
If you can afford the compos do it!. I will be switch to them once I get everything else put on that I want.
AxelR
Yes you still need to grind the huge front calipers for them to work or get a larger spacer. Probably just a few more millimeters.
Compos are the easiest and priciest solution.
I think that is a great option if you are DIY a bit. Those LR3 wheels do look good and the price is great.
Did you have to do the frame horns? for lets say 265/65R18? Or is that just for larger sizes?
