Another Tire Question
pat955
275/55/R19 Tire on my stock 19x8 Wheel? Or Just stick with the stock 255/55/R19 I just want meatier tires.
jim6090
Issues
You are asking for issues changing the wheel diameter. You must go and have computer updated with the different tire diameter. I believe I have read it it can be done.
AxelR
The size will be 30.9". You'll be fine.
Def no need to update the computer, this is not a MB G-Klasse.
pat955
Good to know, so the extra tire width shouldn't be an issue in terms of turning and whatnot?
Surfrider77
Most of the turning issues people experience are a diameter issue with the tire hitting the frame horns, not so much a width issue. I run 285 width on mine.
pat955
Awesome, Obviously not going to be doing any off roading with 275/55R19, was thinking of going with a more road friendly tire like the Pirelli Scorpion Zero or Continental $x4 Contact, feedback?
pat955
Also is it safe to run 275 width on the stock 8" wide wheel? Seems like it would because in Surfrider77's example the compomotive's he is running are also 8" wide.
AxelR
Each tire has a different requirement for rim width. You should find that spec online or call a tire shop.
I think you'll be fine.
pat955
Just checked should be good, tire rack tire width 7.5-9.5 for that size, do you guys have your tires mounted at the dealer or independent? I am going to be in for service soon and figured they could mount them. Also for those who know what does the 50k service consist of?
PE_in_UAE
