97rover
- Joined
- Nov 14, 2005
- Posts
- 137
- Reaction score
- 0
maintenence history : changed oil every 3000 + miles. about 3 months ago replace plugs, wires and coil packs....OUTCH...... on coil packs. also change air filter last oil change. About 1 month ago replaced sensor on anti lock brakes. Front driver side. I had to replace valve cover gaskets to cure my oil leak. 2 weeks ago replace gas filter, had to remove rear right tire to get to it. Replaced filter cause every time it would go uphill i would gas it and it would gear up and sputter/ choke untill i let up on the peddle and it would gear down. still driving it but every time i put it under load it will spit and sputter
also at low idle like starting i have to peddle it a couple of time to get it started......any thoughts? 97 disco with 173000 miles. i am the second owner first put alot into it I have owned it for two years.
